Re: Ford 8n Front loader Control Rebuild kit
Posted by Josh on August 19, 2019 at 08:18:18 [URL] [DELETE] :
In Reply to: Re: Ford 8n Front loader Control Rebuild kit posted by TheOldHokie on August 18, 2019 at 12:37:59:
you're absolutely right, that's the loader that I have. I wish it would give me more room around the engine bay to do work but other than that it seems nice. I'm going to go ahead and order the valve that you suggested and will be in touch once it comes in. In the mean time, I put my old valve back in as the one I bought off of ebay was just garbage. So I have an additional question, how do you bleed the system? The gentleman that I purchased it off of said that the system bleeds itself but it seems like it jumps quite a bit after putting the old valve back on where it did not do that before. I've also noticed that the fluid is quite warm. I'm assuming this is because there's air in the system causing things to warm up. What do I do to bleed the system?
