Re: 19-3 snow blade?
Posted by Charles on August 19, 2019 at 16:32:57 [URL] [DELETE] :
In Reply to: 19-3 snow blade? posted by Keith Calhoun on August 17, 2019 at 21:40:14:
I have fabricated and used the skids on my J-1. bulldozer blade, which I also use as a snowplow blade. I have discarde them as the tilt snowolow makes them useless and dig in unfrozen gravel The skids don't work too weell on budozing. I have it mounted on a 2N.
Instead I leave the 13 hole drawbar on the lift arms. I then run a chain from the drawbar to the center 3 point and adjust the chain to blade depth desired. If the driveway doesn't dip too much, I can keep the blade about 1" above the wet gravel and run at 6-8 miles /hour ' in high range and 2nd gear.
Charles krammin
