Re: Sporadic Rad coolant leak
Posted by Tim Daley(MI) on August 21, 2019 at 01:49:08 [URL] [DELETE] :
In Reply to: Sporadic Rad coolant leak posted by Kevin Fisher on August 20, 2019 at 14:15:04:
There is a petcock drain plug on the bottom of the radiator and often that will leak when idle. Put a container under it next time you park it and see if that is root cause. If so, then you can evaluate how much is leaking and if not an excessive amount, don't worry about it. Just run thru the standard check list of all fluids before you fire up the engine to verify all oils and water are good. If water is low, top it off like you would with your oil.
