Re: 8N Ring Gear
Posted by Tim Daley(MI) on August 23, 2019 at 06:59:42 [URL] [DELETE] :
In Reply to: 8N Ring Gear posted by Cal Sexsmith on August 22, 2019 at 13:44:20:
Take heed with what Bruce said. Your “mechanic” mucked up by using the wrong ringgear whether intentionally or not. He either didn’t know or had one he wanted to get rid of. Don’t pin it. Take it back and demand a refund. People tend to accept pee-poor quality these days and not enough folks complain and do what is right –return it. Now, I cut my teeth on NC Machining turning Ford 6375 flywheels for service in 1975, and we did all the machining and assembling including sweating ringgears on, balancing, and packing in individual Ford labeled boxes. I have the original blueprints for all those flywheels and ringers, including the N-Series Tractors, and the ringgear is tempered steel with the I.D. 1/16” (.06”) smaller than the diameter of the ringgear diameter of the flywheel cold. Ringgears were heated up then set on the flywheel by hand in a gas oven. If your guy won’t rectify the problem with the correct ringgear, p/n 9N-6384, get your money back and go to Dennis Carpenter or Just8Ns and get the right one.
