Re: 861 Powermaster Pie Weights
Posted by Ultradog MN on August 23, 2019 at 16:26:36 [URL] [DELETE] :
In Reply to: 861 Powermaster Pie Weights posted by Mike on August 23, 2019 at 13:39:04:
One word of advice on the segment to plate bolts:
You can get by with grade 2 or 5 bolts but for sure use grade 8 washers.
Grade 2 washers will deform and allow the bolts to loosen. Had that happen to me but noticed a couple of segments were loose and replaced all the washers.
By the way, a plug for my pal Kenny;
He's 83, starting to thin the herd a bit and will probably be selling of a set of heavy 24" pie weights soon. Those are probably the hardest type to find.
In Minneapolis MN.
