Re: 8N Stopped Firing Up
Posted by Tom Wenrich on August 25, 2019 at 11:30:22 [URL] [DELETE] :
In Reply to: 8N Stopped Firing Up posted by AJ Derrick on August 25, 2019 at 08:33:34:
My 8N got harder to start over time. The spark was weak but new points did not solve it. Finally I used a volt meter to check voltage and had 6 1/2 volts at the battery but only 5 after the ignition switch. Replacing the ignition switch was the solution. Try to evaluate the problem.
