Re: 8N Stopped Firing Up
Posted by Anthony on August 25, 2019 at 16:24:27 [URL] [DELETE] :
In Reply to: Re: 8N Stopped Firing Up posted by K.LaRue-VA on August 25, 2019 at 11:08:57:
Thanks for the help. When you pull a plug wire to check for spark. Will I hook up an old, cleaned up plug to the wire, hold with insulated pliers to block / ground and then crank ignition.
Also, when using a volt meter, do you test with both leads on the test point? ... or hot on wire and other lead to ground.
sorry, for the basic nubie questions.
