Re: 52 8N trans/hyd/RE fluid change
Posted by Ultradog MN on September 17, 2019 at 17:26:22 [URL] [DELETE] :
In Reply to: 52 8N trans/hyd/RE fluid change posted by lyle on September 16, 2019 at 15:28:09:
So ummm...
Get two 5 gal pails and switch them when the first one gets half or 2/3 full. Yeah, you'll dribble a bit when you push the empty one under the flow but if you're prepared and quick about it it won't be more than a tablespoon or so.
Half full pails are easier to lift, cary and dump at the recycling center too.
