Re: 8N Headlights
Posted by Bruce (VA) on September 28, 2019 at 20:12:38 [URL] [DELETE] :
In Reply to: 8N Headlights posted by Tom S. on September 28, 2019 at 19:57:03:
Your headlights should be wired independently from the ignition switch. If you run the lights through the ignition switch, it will burn out.
99% of light problems are rust at the mounting brackets. You need clean grounds for the lights to work.
Check for battery voltage t the socket. If it's ok, the problem is the grounds.
