No Spark
Posted by Dean on September 30, 2019 at 13:19:39 [URL] [DELETE] :
I have a 41 9N 6v front mount distributor, that was giving me intermittent problems. It would suddenly die, but restart after a few minutes, It finally stopped running and will not start. I have 6v to the top of the coil. I pulled out the distributor and check my point and gap on all 4 lobes, all was good, checked for potential shorts and continuity in all the places it should have continuity and all was OK, replaced the condenser with one that I know is good as well as the rotor, the cap is also new. Swapped the coil with one off my 8n that was running and put in new plugs. Still no spark. I also noticed that there is no reading on my amp gauge when cranking. I am at a loss, any help would be great. Thanks
