Re: Weight limit on the hydraulic lift of a "50 8N
Posted by R geiger on October 03, 2019 at 23:22:04 [URL] [DELETE] :
In Reply to: Re: Weight limit on the hydraulic lift of a "50 8N posted by Patricia on October 03, 2019 at 21:07:37:
Both the Sherman and hupp slow the tractor down but they also slow the pto down at the same time. A Howard gear box was made to run a rototiller, as it slows the tractor down without slowing the PTO. If the ground is fairly soft you may get away with it.
Good Luck
