Re: hydraulic issue Ford 600
Posted by Ultradog MN on December 04, 2019 at 17:12:25 [URL] [DELETE] :
In Reply to: Re: hydraulic issue Ford 600 posted by Tim Daley(MI) on December 04, 2019 at 13:13:33:
I would not even think about doing anything with/to the pump at this point. Just address the stated problem - he has to hold the draft lever to make the 3 point work properly. I think a new cam follower pin will fix that.
But... Since he has to pull the cover to do that then by all means replace the piston seals and readjust linkage while you're in there.
IF there is also problem with his pump I would address that as a seperate piece once he's done the top cover and only after he has tested the pump pressure with a gage.
We don't even know if he has a vane pump or piston pump yet so let's not get ahead of ourselves on pumps or parts for them.
