Re: Tire chain size
Posted by duey on December 10, 2019 at 22:12:17 [URL] [DELETE] :
In Reply to: Tire chain size posted by Farmer Dan on December 10, 2019 at 14:39:52:
The WIDTH of the chains is almost more important than the LENGTH.. The wider the crosslinks, the shorter the side chains can... and must... be, to fit a given tire.
The shorter the cross links, the Longer the side chains would need to be.
SO if you wanted to cover half the tire, that requires a fixed length cross link... and that would then determine the "length" of a 'laid out' chain assembly. I suppose it could be calculated but for most of us, maybe trial and error is easier. :-)
