Re: Distributor installation
Posted by Bruce (VA) on December 11, 2019 at 15:48:43 [URL] [DELETE] :
In Reply to: Distributor installation posted by Jessie Peterson on December 11, 2019 at 11:08:32:
As Rusty said..... it's possible to put it back on wrong & break it. Look at the slot on the end of the cam shaft. Whatever angle it happens to be, turn the distributor tang to match it. Make sure you can tell the wide side from the narrow side on both the cam & distributor! (close counts). Place the distributor on the front of the engine, gently push it in place & slowly turn the distributor body until you feel the tang slip into the slot. Rotate the distributor body until the bolt holes line up. Hand tighten the two bolts until the distributor body is flush with the timing gear cover.
