Re: SOS tranny
Posted by Dean on December 17, 2019 at 08:43:32 [URL] [DELETE] :
In Reply to: SOS tranny posted by poderac on December 17, 2019 at 08:23:55:
There is more than one design of the S-O-S transmission. What model tractor do you have?
Transmission uses CNH Ambra oil or equivalent. Only one sump in transmission.
The S-O-S has a filter. Where it is located depends upon the model of the tractor. Pre 65 is beneath the top cover. Post 64 is serviceable from the exterior on the left side.
Note: DO NOT attempt to remove the top cover until you have read and understood the procedures for doing so in the correct Ford service manual. Use of improper procedures can result in expensive damage, even resulting in the need for parts that are no longer available.
Dean
