Re: 9n has a Short
Posted by JMOR on December 23, 2019 at 18:41:10 [URL] [DELETE] :
In Reply to: Re: 9n has a Short posted by Dean on December 23, 2019 at 11:33:38:
I question what it is that you define as a "short". Reason being, that the armature in that generator is about 0.1 Ohm or less, so with 'trusty Ohmmeter' in hand, you are all set for a misdiagnosis. Remove belt from generator, apply battery power to gen terminal and if it spins like an electric motor, you do not have a short in that generator. Furthermore, if cut out is good, it disconnects gen from system when engine off, so even if gen had a short, it would not discharge the battery.
