Update
Posted by Dean on December 24, 2019 at 12:12:20 [URL] [DELETE] :
In Reply to: 9n has a Short posted by Dean on December 22, 2019 at 19:59:32:
Thanks for all of the help. Removed the generator and it seems to work fine. When hooked up I am getting 6.8 volts at the battery. I do have the tensioner. The cutout relay seems to be working. With the can off I can observe it opening and closing as it should. with a digital multimeter, I am seeing a reading of 34 ohms between the terminal on the generator and the case. I am getting the same reading between battery cables (battery disconnected and ignition off). When the generator is disconnected at the terminal I have no reading between the battery cables, raining hard today so I cant work on it. If it matters, the SN is 9N51774
