Re: Update
Posted by JMOR on December 24, 2019 at 16:04:33 [URL] [DELETE] :
In Reply to: Update posted by Dean on December 24, 2019 at 12:12:20:
Some observations/comments:[]
" Removed the generator and it seems to work fine. When hooked up I am getting 6.8 volts at the battery. I do have the tensioner. The cutout relay seems to be working. With the can off I can observe it opening and closing as it should. with a digital multimeter, I am seeing a reading of 34 ohms between the terminal on the generator and the case." [If you mean gen terminal and gen case, then either you are reading meter wrong or have bad meter connection, because generator armature should be less than ONE ohm.] "I am getting the same reading between battery cables (battery disconnected and ignition off)." [That should be open circuit, i.e., infinite resistance.] "When the generator is disconnected at the terminal I have no reading between the battery cables" [Generator connected or not should make no difference, as cut out should already have generator disconnected from battery cables/all tractor circuits, except gen terminal of cut out.], raining hard today so I cant work on it. If it matters, the SN is 9N51774
[You might wan to verify that gen is connected to cut out gen terminal and not the battery terminal of cut out.]
