Re: Another 641 fuel valve replacement
Posted by Tim Daley(MI) on December 26, 2019 at 14:45:30 [URL] [DELETE] :
In Reply to: Another 641 fuel valve replacement posted by Mike in Michigan on December 22, 2019 at 21:40:55:
Can you post the LINK to the HOW-TO's article here with the pictures that are no longer viewable? I didn't see anything under FUEL SYSTEM. It's a good bet the pictures were saved with Photobucket and if sender did not renew with a fee-based account now are not able to post and they will be all blurred. If we see who posted it, perhaps we can get them to save under IMGUR or other account and repost the entire article with those. Question #2 - FITTINGS ARE SPECIAL UNS 7/16-24 USED ON BRAKE AND HYDRAULIC LINES. This includes sediment bulb connections, brass elbow fittings, and fuel line fittings. Many of us eschew using plastic, copper, nylon, or rubber FUEL LINES and advise NOT recommended to use. 1/4 Steel is best. A flaring nut tool kit and tubing bender are your friends. Are you anywhere close to Lapeer County? If so I could pop in and help you run new steel lines. Email is open.
