Re: 1940 9N Electrical system
Posted by Robert Angney on January 14, 2020 at 07:31:36 [URL] [DELETE] :
In Reply to: Re: 1940 9N Electrical system posted by Tim Daley(MI) on January 14, 2020 at 06:15:48:
Tim, Thank you for all the information. Here are our findings so far:
1. We do have a 6v generator and 6v battery. The generator does not have the tensioning rod that you described yesterday, but it does have two screw holes on the top. I tried to get some pics of the numbers that are stamped you the generator.
It is a 1-wire generator (how do I verify that it's 3 brush?) there is a +/- adjustment screw on it.
2. We do have a roundcan cutout. It is not labeled Batt and Gen like the pics you sent, it just has a "B" on the bottom (does it matter which end is connected to the battery?). Sounds like we need to take the cover off to adjust it?
3. I believe the ignition switch is OEM style. The light switch is a fused 2 wire switch (not hooked up).
4. We reviewed the wiring pictogram last night. Wiring is clearly wrong and some wire are just cut off and dangling.
I likely wont have time to do much this evening. Let keep in touch. I appreciate all your help.
