Re: flywheel gear
Posted by Bruce (VA) on January 15, 2020 at 17:46:19 [URL] [DELETE] :
In Reply to: flywheel gear posted by Scott on January 15, 2020 at 15:15:34:
It's easier to tack weld a slipping ring gear through the starter hole than to split the tractor and do it correctly. The spot-weld fix is usually applied when the ' heat it in the oven, freeze the flywheel' fix didn't work.
Fix it right or have it fixed right.
