Re: flywheel gear
Posted by Tim Daley(MI) on January 16, 2020 at 16:42:28 [URL] [DELETE] :
In Reply to: Re: flywheel gear posted by mhb@ufe on January 16, 2020 at 07:44:34:
Yes, I'm with you -'press fit' not the correct term but thought I'd use the term to not confuse the poster. The correct term is 'interference fit'. A press fit involves a male part fitting into a female part with only .0003" - .0005" tolerance between them and thus are pressed into each other. A good example is pressing a bearing into a bore.
