Re: Ford 4500 Diesel Engine Spec Sheet
Posted by Ultradog MN on January 17, 2020 at 14:33:37 [URL] [DELETE] :
In Reply to: Re: Ford 4500 Diesel Engine Spec Sheet posted by ERIC on January 17, 2020 at 10:10:34:
Model D5012K
D = 4000 chassis built after 4/68.
50 = Industrial
1= Diesel
2= 540 transmission pto
K = 6X4 manual reversing transmission
Unit 3J05B
3 = 1973
J = September
05 = 5th day of the month
B = afternoon shift
Unit B393889
C = assembled in USA
393889 is consistant with a late 1973 serial number
To verify that the tractor is actually the tractor that is listed on the foil tag under the hood (hoods are easily changed)
Look on the bell housing just above andbto the rear of the starter. There will be some numbers Hand Stamped there. NOT raised cast numbers.
You will likely have to scrape some rust, paint and crud off to see them. See photo for example.
