Re: steering box
Posted by Tim Daley(MI) on January 27, 2020 at 17:13:57 [URL] [DELETE] :
In Reply to: steering box posted by gary on January 27, 2020 at 12:39:43:
Don’t go by the Operator’s Manual. It says to pull acorn nut off and pour hydraulic o il down the steering shaft. That will only get you a mess and wasted oil. The steering gear lube ports are on the RH side of the steering shaft behind the dash on both styles. The early box uses a 1/4" NPT plug and the late box uses a 7/16 hex bolt. Both still are not easy to get oil into. I modified some for both with new NPT plugs and new hex bolts then drilled thru and tapped out to insert Zerk fittings to make lubrication a much cleaner and easier method. I also use cornhead grease but some don’t like that. I have no issues with it so to each his own. Chances are the bearings and seals are gone so a steering box rebuild is in your future.
FORD TRACTOR STEERING BOX –AFTER S/N 216988 FROM THE I&T FO-4 MANUAL:
TIM DALEY’S MODIFIED STEERING BOX LUBE PLUGS w/ZERKS:
EARLY 8N BOX USES A 1/4” NPT PLUG; ZERK IS MODIFIED:
LATER 8N BOX USES A 7/16-14 HEX BOLT; ZERK IS MODIFIED:
