46 2N
Posted by Douglas on January 28, 2020 at 12:01:15 [URL] [DELETE] :
a friend of mine just picked up a 46 2N that is still a 6 volt system. onething he has noticed so far is it will be needing a head gasket. it is set up as a negative ground not positive ground. is this a mistake from the PO or can it remain a negative ground. with a little fresh gas it did run as it is now.
