Re: Distributor rotation
Posted by Tim Daley(MI) on January 31, 2020 at 05:36:05 [URL] [DELETE] :
In Reply to: Distributor rotation posted by Jim on January 30, 2020 at 19:45:29:
HiYa Jim-
Here’s some vital data on the Ford N-Tractor Front Mount Distributor. Firing order is 1,2,4,3 CC as viewed from the front of engine. FYI: Firing Order on the angle (side) mount also is 1,2,4,3. Do you own copies of the Essential Manuals? If not, invest in them; they are the most valuable tool you can have. The Front Mount Unit is timed off the tractor and on your bench. Breaker Point gap is .015” and timing is set according to instructions in the manual. Mounting is done one correct way only – cam is offset and distributor cam and weight tang is offset –THEY MUST MATCH! If mounted off 180°, it will destroy the aluminum base unit the second power is applied and render as scrap. If you need help rebuilding your front mount, Farmer Dan (dansden@usa.com) has some OEM units all ready to go, guaranteed quality parts and workmanship.
FORD TRACTOR FRONT MOUNT DISTRIBUTOR FIRING ORDER; 1,2,4,3 CCW:
FRONT MOUNT TIMING PROCEDURE:
FORD FRONT MOUNT DISTRIBUTOR – WHAT HAPPENS WHEN MOUNTED 180° OFF:
FORD 8N TRACTOR WIRING DIAGRAMS:
***NOTE: Diagrams shown with OEM Correct Color Codes for wiring. Never use wire colors as a test; colors do not conduct electrons. Always use a VOM set to CONTINUITY.
FORD 9N/2N TRACTOR ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
Tim *PloughNman* Daley(MI)
*9N653I* & *8NI55I3*
