Re: 1948 ford 8n fuel issue
Posted by Tim Daley(MI) on February 12, 2020 at 05:14:37 [URL] [DELETE] :
In Reply to: 1948 ford 8n fuel issue posted by thad on February 11, 2020 at 20:41:39:
Fuel thru the air intake port throat indicates the float and/or needle valve is stuck usually. A recent member here, scroll down 2 threads to see 8N FLOODING, had the same issue and turned out it the needle float valve seat was loose. Use a wide blade chisel type tool to tighten the brass insert. A regular screwdriver won't do it and just booger up the bars slot. There is also a gasket underneath it; use it.
MY CARB TOOLS:
