Re: Throttle lever, governor, carb, or combo?
Posted by deanostoybox on February 21, 2020 at 19:58:24 [URL] [DELETE] :
In Reply to: Throttle lever, governor, carb, or combo? posted by Travis on February 21, 2020 at 12:17:22:
Thee is a lever (throttle control rod) PN 8N-9807 at the bottom end of the Arm (throttle rod) PN 8N-9805. The arm is clamped to the arm with a screw. If that arm is loose it can cause the problem you are describing.
