Re: 8N bogs down when turning on PTO and pulling shredder
Posted by Tim Daley(MI) on March 03, 2020 at 03:51:51 [URL] [DELETE] :
In Reply to: 8N bogs down when turning on PTO and pulling shredder posted by Steve on March 02, 2020 at 21:09:52:
Did you perform the Fuel Flow Test first? Did you buy a new aftermarket carb and just install it without checking and testing it? Do you still have your OEM Marvel-Schebler carb? If so, send it to me and I'll rebuild it. Just replacing parts without doing a true root cause problem solving method is not the way to proceed -for any problem. Ethanol-Free gas is NOT needed and isn't your problem. 99.98% of all non-running issues are due to incorrect wiring, BUT, don't assume anything, test. Are you running the OEM 6V/POS GRN electrical system or did you switch it to 12V? Many fuel issues turn out to be electrical and vice versa. Got the Essential Manuals? Start with fuel test. Pass = move on to carb and governor settings. Fails = determine root cause, fix, and report back. My email is open.
