Re: Source for odd ball tie rod ends
Posted by Ultradog MN on March 04, 2020 at 18:18:45 [URL] [DELETE] :
In Reply to: Re: Source for odd ball tie rod ends posted by mhb@ufe on March 04, 2020 at 08:39:55:
Many thanks Mark!
Mine is a 1966. The upper one at the link should fit.
The lower one is mostly correct except I will need to make a bushing to convert the taper to straight.
The steering on this tractor has taken a bit of work to get it fixed up. Most of the parts are NLA so you have to make things for it.
