Re: Ford 8N tractor starter won't disengage, Positive Drive type
Posted by Tim Daley(MI) on March 09, 2020 at 03:15:13 [URL] [DELETE] :
In Reply to: Ford 8N tractor starter won't disengage, Positive Drive type posted by Brad Cobb on March 08, 2020 at 21:01:31:
Model year is irrelevant. Do you have a front mount distributor or the angle (side) mount style? Are you trying to run a 12V switchover system or is it the OEM 6V/POS GRN setup? Either way, have you verified the wiring is all correct? Don't guess and start replacing parts until the true root cause is determined.
