Re: 49' 6 volt positive ground cable HOT!
Posted by Tim Daley(MI) on March 21, 2020 at 12:20:10 [URL] [DELETE] :
In Reply to: 49' 6 volt positive ground cable HOT! posted by Harry on March 21, 2020 at 11:43:45:
NO! Battery cables or anything else except the ballast resistor gets that hot. You have mucked up wiring. Don't try to start with gas til it is corrected. Did you follow 'WIRING PICTIGRAMS by JMOR' from the HOW-TO's/ELECTRICAL from here? Here is a page for the 6V/POS GRN setups:
CORRECT FORD 8N ELECTRICAL SYSTEMS - 6V/PO GRN; FRONT MOUNT & SIDE MOUNT:
*PICTOGRAM courtesy of JMOR
Tim *PloughNman* Daley(MI)
*9N653I* & *8NI55I3*
