Re: Headlights Ground Wire
Posted by Robert Angney on March 23, 2020 at 12:58:10 [URL] [DELETE] :
In Reply to: Re: Headlights Ground Wire posted by Dean on March 23, 2020 at 09:30:31:
Thank you. Here is what we tried. Since the rear work light works, we took it apart to see where the ground wire was and there was no ground wire, just a wire that went to the switch. We then tested the front lights by grounding them to the headlamp housing and that didn't work. Is the ground wire separate from the the wire that goes to the switch? Is there a specific place to connect the ground wire?
