Re: Advice on centre housing
Posted by TheOldHokie on March 24, 2020 at 11:29:27 [URL] [DELETE] :
In Reply to: Advice on centre housing posted by Kimberly on March 24, 2020 at 10:11:51:
That would be really pushing your luck. I can tell you the pinion nut on my Dodge truck worked loose and I dropped the pinion at no more than 10 MPH. It looked like a grenade went off inside the housing and blew a hole in the side. That wound up being an entire rear end swap from a salvage vehicle.
TOH
