Re: Rotary mower and shaft length
Posted by Tim Daley(MI) on April 02, 2020 at 08:36:25 [URL] [DELETE] :
In Reply to: Re: Rotary mower and shaft length posted by Pete on April 02, 2020 at 07:26:53:
Everybody calls a brush hog a 'Bush Hog', just the nature of the beast now. Option? What do you mean? There are two bars, two fender brackets and the link pins and check chains to fasten with. You will also need longer hex bolts for the fender brackets. The bars fasten to the lower lift arms. The fenders get the brackets attached to the bottom of the axle bosses. The other end of the bars fasten to the brackets. The setup must be installed one correct way so as to not damage the lift arms and pump. SEE LINK
