Re: starting
Posted by John in Mich on April 02, 2020 at 17:58:14 [URL] [DELETE] :
In Reply to: starting posted by david on April 02, 2020 at 15:43:30:
Carb is flooding and you have wet/fouled spark plugs. Pull the spark plugs and clean or replace them. Turn the gas valve off so that you cannot flood the carb. There is enough gas in the bowl to run for several minutes. Once running, turn the gas back on.
