Re: 2N No Power
Posted by Jack - Iowa on April 04, 2020 at 06:49:09 [URL] [DELETE] :
In Reply to: Re: 2N No Power posted by Jason Dunderman on April 03, 2020 at 12:17:20:
Jason,
If you pull that distributor, I highly recommend you note the position of the rotor before you rotate ANYTHING! On the back there is a tang which fits into a slot. It is offset and if you force it together wrong, you will be looking for a new distributor. Learned the lesson the hard way on a 1941 auto many years ago.
They are not difficult to remove or re-install.
Good Luck,
Jack
