Re: Leaking hydraulic pump assembly drain plug bolt
Posted by TheOldHokie on April 04, 2020 at 20:59:46 [URL] [DELETE] :
In Reply to: Leaking hydraulic pump assembly drain plug bolt posted by Travis Webb (UT) on April 04, 2020 at 19:18:59:
What bolt are we talking about? I'm guessing you mean the plug in the test port - right front corner of the pump. It should have a copper sealing washer on it. If that is present and it's still leaking I would suspect a cracked pump housing.
TOH
