Re: Leaking hydraulic pump assembly drain plug bolt
Posted by TheOldHokie on April 04, 2020 at 21:31:58 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by Charles on April 04, 2020 at 21:16:56:
The test port is not taper pipe thread. It is 1/2-20 UNF and the plug is a standard fine thread cap screw with sealing washer. Screwing a pipe plug into the test port is an easy and quick way to crack the base of the pump.
TOH
