Re: Leaking hydraulic pump assembly drain plug bolt
Posted by TheOldHokie on April 05, 2020 at 05:52:24 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by Travis Webb (UT) on April 04, 2020 at 21:45:38:
That is the test port plug. It is supposed to be a 1/2-20 hex head bolt with a sealing washer under the head. If the washer is missing that might be the cause of your leak but I would expect it to be a slow drip not a stream. Can you post a picture of the plug? I dont want to be an alarmist but it sounds like someone may have replaced the bolt with a pipe plug and cracked the pump housing. Hope that is not the case.
TOH
