Re: Leaking hydraulic pump assembly drain plug bolt
Posted by TheOldHokie on April 05, 2020 at 12:29:30 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by Travis Webb (UT) on April 05, 2020 at 11:05:14:
Washer is missing. I would put one on and check again. Hard to tell if that is a crack but now that you are looking for it you should be able watch it under pressure (raised weight on lift) and see if the flow is coming from that area. Just how much flow are you getting - drip or stream?
