Re: Leaking hydraulic pump assembly drain plug bolt
Posted by TheOldHokie on April 05, 2020 at 14:59:43 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by Travis Webb (UT) on April 05, 2020 at 13:57:47:
Now that is what I was expecting. Someone probably screwed a taper pipe plug in there and split the boss. Little to no pressure there until the lift is raised. If it were me I'd be researching aluminum braze or Muggyweld. The threads are probably munged as well so thread repair insert is probably going to be needed. Good news is pumps are plentiful and not real expensive.
TOH
