Re: Leaking hydraulic pump assembly drain plug bolt
Posted by Travis Webb (UT) on April 05, 2020 at 19:21:32 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by TheOldHokie on April 05, 2020 at 18:39:48:
Thanks. If I decided to try to braze it, is the trans fluid flammable? Should I remove the pump first?
