Re: Pie wheel weights
Posted by Kirk-NJ on April 07, 2020 at 04:46:48 [URL] [DELETE] :
In Reply to: Pie wheel weights posted by Brad on April 06, 2020 at 14:54:17:
So I'm guessing you are looking to add some weight to the 8n. I don't think Making the pies is a good option cause you would still need to make a plate and you would still need a mounting plate, 24 bolts and washers and 16 (ain't cheap) adapter lug nut's. Here might be a couple of options for you. The half moon weights. I have seen these homemade also. I have seen these weights in an inch to inch and a half thick weighing about 60/70 lbs each. you can also stack them to get the weight you need. I've had them in 2" thick and they weighed 100 lbs each segment. These would be mounted on the inside.
