Re: Pie wheel weights
Posted by JK-NY on April 07, 2020 at 14:51:41 [URL] [DELETE] :
In Reply to: Re: Pie wheel weights posted by Brad on April 07, 2020 at 14:08:01:
Iím not sure why you feel the need for adding oil to used antifreeze for ballast purposes. If anything it might be detrimental as it might affect the rubber inner tubes. Electrolysis affects metals, not rubber which inner tubes and radiator hoses are made of so that wouldnít be a factor for ballast purposes. Not sure where you are located, windshield washer fluid may be adequate in some areas for freeze protection, as well as just using water in a warm enough climate. I would recommend using inner tubes in tires with any liquid ballast, itís pretty much an industry standard .
