Re: 2N
Posted by Tim Daley(MI) on April 07, 2020 at 16:48:52 [URL] [DELETE] :
In Reply to: Re: 2N posted by JR in AR on April 07, 2020 at 08:12:48:
OK, you need a 12V battery, a 12V alternator, with the generator and cutout removed from the circuit. the OEM Ballast Resistor and OEM front mount distributor are still required. If you use a 6V coil you need to add an external in-line ceramic 1-OHM resistor. If you replace with a 12V coil no need to add the extra resistor. You can get all the Wiring Pictograms downloaded for free in our HOW-TO's forum under Electrical.
FORD 9N/2N WIRING 6V & 12V:
FORD N-SERIES TRACTOR FRONT MOUNT DISTRIBUTOR 9N-12250 BALLAST RESISTOR:
EXTERNAL IN-LINE 1-OHM CERAMIC RESISTOR REQUIRED WITH THE FRONT MOUNT DISTRIBUTOR WHEN USING A 6-VOLT COIL:
