Re: Pie wheel weights
Posted by JK-NY on April 07, 2020 at 20:25:04 [URL] [DELETE] :
In Reply to: Re: Pie wheel weights posted by Brad on April 07, 2020 at 16:27:50:
Maybe we are thinking about different things when we say “antifreeze .” I am not referring to calcium chloride/water , the traditional liquid ballast . I am referring to used automotive or truck coolant , which is not corrosive or flammable . If you can find a source to get enough for free to load your tires it’s a good alternative to more expensive choices. I apologize if I didn’t explain it well in the other posts . As far as calcium chloride solution , I have 2 tractors with calcium chloride ballast (and one more with pie weights that I removed the calcium fluid from). The secret to avoiding corrosion from this type of ballast is to fix any leaks immediately .
