Re: 8N rototiller fabrications
Posted by Brad on April 08, 2020 at 17:52:29 [URL] [DELETE] :
In Reply to: Re: 8N rototiller fabrications posted by steveVa on April 08, 2020 at 16:00:57:
"Get a variable speed electric motor with a small but fat tire and use that small diameter tire to drive the rear tractor tire"
Interesting reply and intriguing suggestion :-)
I have seen electric bicycles set up such as you've described: a small electric motor turning a wheel which rubs on and pushes the bicycles tire 'round, but I must admit I never would have thought of applying concept to tractor. That is thinking outside the box! :-)
None doubt Ford 8N's 540 PTO capably powering rototiller's tines with sufficient power, problem comes in with too high of ground speed, where your method could certainly get around speed-restriction issues.
It's all about slowing tractor's speed down, while maintaining PTO speed and giving tiller tines sufficient time in performing their function.
With a walk-behind garden tiller, to keep tiller from taking off & "walking" across ground instead of tilling, you have a flip-down "leg" keeping tiller in place & forcing tines to remain in place so they do their job of digging/tilling/chopping. This is the phenomenon behind Bruce's #74 of "Tips for Ford 8N Tractor Owners" quote: "..sandy loose soil and putting the tractor in neutral and letting the tiller push the tractor."
I can conceive a number of applications maintaining slow ground speed desired, while PTO remaining at required 540 RPMs for rototiller usage, I just can't see any cost-effective way of doing it, versus purchasing a "good enough" used cultivating-spring-harrow (different names for this implement in different parts of country) that will get the job done. There's an old Russian proverb: "Perfect" is the enemy of "Good Enough."
Come to think of it, according to proverb, I'm so far from "perfect," I should have lots of "good enough" friends ;-) lol
