Re: Affordable Quick Fix to Protect Positive Battery Terminal
Posted by Bruce on April 12, 2020 at 09:03:11 [URL] [DELETE] :
In Reply to: Affordable Quick Fix to Protect Positive Battery Terminal posted by Administration on April 12, 2020 at 08:00:13:
Shouldn't this be applied to the NEGATIVE battery post, as 6v N's were positive ground? In other words, it's the " hot" terminal that needs the insulator from grounding.
If you have a negative ground tractor, as in 99% of all 12v conversions, then the application shown would work as desired.
But you get nothing from applying an insulator to the positive battery post of a positive ground tractor.
