Re: Leaking hydraulic pump assembly drain plug bolt
Posted by Travis Webb (UT) on April 13, 2020 at 13:45:31 [URL] [DELETE] :
In Reply to: Re: Leaking hydraulic pump assembly drain plug bolt posted by TheOldHokie on April 05, 2020 at 20:04:15:
Tried to braze it, but no luck. Look at it closer, and the threads are cracked. I ordered a new pump, and pump base gasket. My understanding is that I drain the fluid, remove the PTO shaft from the rear of the tractor, unbolt the pump and drop it out. To replace, I would remove the inspection doors on each side, line up the lever with the plunger, and bolt the pump back in; replace the PTO shaft, and fill up with new fluid. Is that right? So my parts list would be a new pump, PTO gasket, two inspection door gaskets, 3 drain plug gaskets, and a pump base gasket. Am I missing anything?
